Re: [gdal-dev] RedHat build error: `TIFFFreeDirectory' was not declared in this scope
Lucena, Ivan ivan.lucena at pmldnet.com
Fri Nov 21 15:32:31 EST 2008
Thanks Even. I am going to try that.
>  -------Original Message-------
>  From: Even Rouault <even.rouault at mines-paris.org>
>  Subject: Re: [gdal-dev] RedHat build error: `TIFFFreeDirectory' was not declared in this scope
>  Sent: Nov 21 '08 20:12
>  Ivan,
>  See http://n2.nabble.com/get-fmrt-grib-td1313401.html.
>  I think someone recently reported that issue and if I remember well, RHEL 4 is
>  shipped with libtiff 3.6 that doesn't have TIFFFreeDirectory.
>  So the workaround is
>  to ./configure --with-libtiff=internal --with-libgeotiff=internal
>  (passing the path inside the gdal tree is not supposed to work. The path of
>  the --with-libtiff and --with-libgeotiff configure options must point to an
>  installed version of those libraries, not a source distribution)
>  We should probably put libtiff 3.8 as the minimum requirement. See
>  http://trac.osgeo.org/gdal/ticket/2668
