[gdal-dev] loading many files with C API
Yann Chemin yann.chemin at gmail.com
Mon Nov 24 08:14:30 EST 2008
Hi again,
the first problem was an input output argv[] confusion. I can load 350
files and it is OK. I may have another problem at the pixel level, but
in case i'll start a new thread.
Thank you Ivan for your suggestion, it would be meaningful indeed to do that.
void usage()
	printf( "-----------------------------------------------------------\n");
	printf( "--Calculate the frequency of occurrence of an event--------\n");
	printf( "./freq outFREQ infile1[ infile2 infile3 ...] \n");
	return;
int main( int argc, char *argv[] )
      	if( argc < 5 ) {
		usage();
		return 1;
	int 	i, row, col;
        char	*in[MAXFILES];
	char	*out;
	int 	imgs_per_year;
	int	n_imgs;
	int 	n_null_pix;
	GDALDatasetH hDataset[MAXFILES+1];
	GDALAllRegister();
	GDALDriverH hDriver[MAXFILES+1];
	GDALRasterBandH hBand[MAXFILES+1];
	float *pafScanline[MAXFILES+1];
	int nXSize1, nYSize1;
	out	 	= argv[1];
	//Loading input files
	n_imgs = argc - 2;
	for (i=0;i<n_imgs;i++){
		printf("%i / %i %s\n",i,n_imgs,argv[i+2]);
		in[i]	= argv[i+2];
		hDataset[i] = GDALOpen(in[i],GA_ReadOnly);
		hDriver[i] = GDALGetDatasetDriver(hDataset[i]);
		hBand[i] = GDALGetRasterBand(hDataset[i],1);
		nXSize1 = GDALGetRasterBandXSize(hBand[0]);
		pafScanline[i] = (float *) CPLMalloc(sizeof(float)*nXSize1);
	printf("Passed 1\n");
	nYSize1 = GDALGetRasterBandYSize(hBand[0]);
	//Creating output file
	hDataset[n_imgs] = GDALCreateCopy( hDriver[0], out,
				hDataset[0],FALSE,NULL,NULL,NULL);
	hBand[n_imgs] = GDALGetRasterBand(hDataset[n_imgs],1);
	pafScanline[n_imgs] = (float *) CPLMalloc(sizeof(float)*nXSize1);
	////////////////// LOAD Pixels and process from there
Thanks
Yann
2008/11/25 Ivan Lucena <ivan.lucena at pmldnet.com>:
> Yann, Frank,
> Another thing to considerer is that any process you might want to do on that
> file storage option will be way much slower than if it was done in a multi
> band, tiled, interleaved by pixel format.
> That is my experience,
> Ivan
> Frank Warmerdam wrote:
>> Yann Chemin wrote:
>>> Hello,
>>> I need to load about 400 files with the C API to work on each pixel
>>> temporal dimension.
>>> I would like to make a look to load them but fail so far...
>>> GDALDatasetH hDataset[MAXFILES];
>>> GDALAllRegister();
>>> GDALDriverH hDriver[MAXFILES];
>>> GDALRasterBandH hBand[MAXFILES];
>>> float *pafScanline[MAXFILES];
>>> int nXSize1,nYSize1;
>>> //loading input files
>>> for(i=0;i<n_imgs;i++){
>>>    in[i] = argv[i+1];
>>>    hDataset[i] = GDALOpen(in[i];GA_ReadOnly);
>>>    hDriver[i] = GDALDatasetDriver(hDataset[i]);
>>> it mentions error 10: 'hDataset' is NULL in 'GDALGetDatasetDriver'
>> Yann,
>> Is that the first error reported?  Does it occur for i==0 or much later
>> (perhaps around the 250th file)? Many operating systems have a limit
>> on the number of files that can be open at once, in some cases around
>> 256.
>> Best regards,
Yann Chemin
International Rice Research Institute
Office: http://www.irri.org/gis
Perso: http://www.freewebs.com/ychemin
YiKingDo: http://yikingdo.unblog.fr/
