[gdal-dev] using GDALCreateCopy and changing only the datatype
Kolberg Sjur A Sjur.A.Kolberg at sintef.no
Mon Nov 24 08:52:23 EST 2008
Hi Yann,
I had this same problem and found no other solution than to switch from CreateCopy() to Create().
Good luck,
Sjur K :-)
Sjur Kolberg
SINTEF Energiforskning A/S
Sem Sælands vei 11
7465 Trondheim
tlf. 73 59 72 78
fax  73 59 72 50
> -----Original Message-----
> From: gdal-dev-bounces at lists.osgeo.org
> [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Yann Chemin
> Sent: 24 november 2008 14:10
> To: gdal-dev at lists.osgeo.org
> Subject: [gdal-dev] using GDALCreateCopy and changing only
> the datatype
> Hello,
> I would like to use GDALCreateCopy and change the datatype
> from int32 to float32.
>         GDALDatasetH hDatasetOut0;
>         hDatasetOut0 = GDALCreateCopy( hDriver1, ndviF,
>                                 hDataset1,FALSE,NULL,NULL,NULL);
>         GDALRasterBandH hBandOut0;
>         hBandOut0 = GDALGetRasterBand(hDatasetOut0,1);
> thanks,
> Yann
> Yann Chemin
> International Rice Research Institute
> Office: http://www.irri.org/gis
> Perso: http://www.freewebs.com/ychemin
> YiKingDo: http://yikingdo.unblog.fr/
> gdal-dev mailing list
