[gdal-dev] using GDALCreateCopy and changing only the datatype
Yann Chemin yann.chemin at gmail.com
Mon Nov 24 08:57:33 EST 2008
Hi Sjur,
I found out that in:
hDatasetOut0 = GDALCreateCopy( hDriver1, ndviF, hDataset1,FALSE,NULL,NULL,NULL);
the FALSE argument was there to inhibit strict identity to the parent
dataset it copies. However, when trying to induce it to write in
GDT_Float64 instead of int32, it brings out the file as int32....
so far for allowing change...
Yann
2008/11/24 Kolberg Sjur A <Sjur.A.Kolberg at sintef.no>:
> Hi Yann,
> I had this same problem and found no other solution than to switch from CreateCopy() to Create().
> Good luck,
> Sjur K :-)
> Sjur Kolberg
> SINTEF Energiforskning A/S
> Sem Sælands vei 11
> 7465 Trondheim
> tlf. 73 59 72 78
> fax  73 59 72 50
>> -----Original Message-----
>> From: gdal-dev-bounces at lists.osgeo.org
>> [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Yann Chemin
>> Sent: 24 november 2008 14:10
>> To: gdal-dev at lists.osgeo.org
>> Subject: [gdal-dev] using GDALCreateCopy and changing only
>> the datatype
>> Hello,
>> I would like to use GDALCreateCopy and change the datatype
>> from int32 to float32.
>>         GDALDatasetH hDatasetOut0;
>>         GDALRasterBandH hBandOut0;
>>         hBandOut0 = GDALGetRasterBand(hDatasetOut0,1);
>> thanks,
>> Yann
>> Yann Chemin
>> International Rice Research Institute
>> Office: http://www.irri.org/gis
>> Perso: http://www.freewebs.com/ychemin
>> YiKingDo: http://yikingdo.unblog.fr/
>> gdal-dev mailing list
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
Yann Chemin
