[gdal-dev] autotest 1.6 errors - need help
William Kyngesburye woklist at kyngchaos.com
Sun Nov 30 17:03:12 EST 2008
I'm working on some autotest errors for 1.6, and I need some help to
figure out how to fix them.
- ogr_gml
   TEST: ogr_gml_1 ... ERROR 1: <coordinates> element missing value.
fail (blowup)
   File "pymod/gdaltest.py", line 89, in run_tests
     result = func()
   File "./ogr_gml_read.py", line 72, in ogr_gml_1
     if feat.GetField('Name') != 'Aartselaar':
AttributeError: 'NoneType' object has no attribute 'GetField'
and similar errors for tests 2-4
strangely, there is a similar error for test 5 but it succeeds:
  TEST: ogr_gml_5 ... ERROR 1: <coordinates> element missing value.
success
Could it have something to do with Xerces 3?  I can try recompiling
with Xerces 2.8.
- tiff_write
   TEST: tiff_write_55 ... PROJCS["Equirectangular
Mars",GEOGCS["GCS_Mars",DATUM["unknown",SPHEROID["unnamed",
3394813.857975945,0]],PRIMEM["Greenwich",0],UNIT["degree",
0.0174532925199433]],PROJECTION["Equirectangular"],PARAMETER["latitude_of_origin",-2],PARAMETER["central_meridian",184.4129943847656],PARAMETER["standard_parallel_1",0],PARAMETER["false_easting",0],PARAMETER["false_northing",0],UNIT["metre",1,AUTHORITY["EPSG","9001"]]]
fail
     failed to preserve Equirectangular projection as expected, old
libgeotiff?
Well, I'm using geotiff 1.2.5, and I notice that GDAL includes 1.2.4.
It's not saying what the difference is.
- gdrivers/grass
   TEST: grass_2 ...
old =  PROJCS["UTM Zone 18, Northern Hemisphere",
     GEOGCS["grs80",
         DATUM["North_American_Datum_1983",
             SPHEROID["Geodetic_Reference_System_1980",
6378137,298.257222101],
             TOWGS84[0.000,0.000,0.000]],
         UNIT["degree",0.0174532925199433]],
     PROJECTION["Transverse_Mercator"],
     PARAMETER["latitude_of_origin",0],
     PARAMETER["central_meridian",-75],
     PARAMETER["scale_factor",0.9996],
     PARAMETER["false_easting",500000],
     UNIT["meter",1]]
new =
fail
     Projections differ
It seems to have completely dropped the projection.  Note that I'm
using a trimmed down library-only GRASS and may have missed something
in the dummy grass/etc/ folder.
- mrsid - I've been getting this for a while, even in 1.5.
   TEST: mrsid_1 ...
old =  PROJCS["MER         E000|",
     GEOGCS["NAD27",
         DATUM["North_American_Datum_1927",
             SPHEROID["Clarke 1866",6378206.4,294.9786982139006,
                 AUTHORITY["EPSG","7008"]],
             AUTHORITY["EPSG","6267"]],
         UNIT["degree",0.0174532925199433],
         AUTHORITY["EPSG","4267"]],
     PROJECTION["Mercator_1SP"],
     PARAMETER["latitude_of_origin",1],
     PARAMETER["central_meridian",1],
     PARAMETER["scale_factor",1],
     PARAMETER["false_easting",1],
     PARAMETER["false_northing",1],
     UNIT["metre",1,
new =  PROJCS["MER         E000|",
     GEOGCS["NAD27",
     PARAMETER["central_meridian",0],
     UNIT["metre",1,
fail
     Projections differ
It's losing most of the parameters or their values.
Then:
   TEST: mrsid_4 ...
old =  (0.0, 255.0, 102.684, 51.613999999999997)
new =  [0.0, 255.0, 103.11236497314, 52.476991490286998]
fail
     Approximate statistics differs.
I think this used to be OK, though I sorta remember seeing it before.
- osr_esri
   TEST: osr_esri_10 ...
Got:
PROJCS["Sphere_Plate_Carree",GEOGCS["GCS_Sphere",DATUM["D_Sphere",SPHEROID["Sphere",6371000.0,0.0]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.017453292519943295]],PROJECTION["Equidistant_Cylindrical"],PARAMETER["False_Easting",0.0],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",0.0],UNIT["Meter",1.0]]
Expected:
PROJCS["Sphere_Plate_Carree",GEOGCS["GCS_Sphere",DATUM["D_Sphere",SPHEROID["Sphere",6371000.0,0.0]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.017453292519943295]],PROJECTION["Plate_Carree"],PARAMETER["False_Easting",0.0],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",0.0],UNIT["Meter",1.0]]
fail
     Did not get expected Plate_Caree SRS after morphToESRI
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
Earth: "Mostly harmless"
- revised entry in the HitchHiker's Guide to the Galaxy
