[gdal-dev] Data Binding dgal Layer in .NET
Evans, Frank fevans at harris.com
Wed Oct 1 08:02:49 EDT 2008
If you provide a few more details I can definitely help. I've written
applications which load GDAL metadata into a GridView, but the trick is
arriving at a table-schema which is consistent for  multiple types of
layers/images. .NET grids bind to a Data source which could be anything.
What type of layer are you trying to use to populate your DataGridView
(an image, a shapefile)
To clarify, the OSGeo.GDAL.Dataset is a completely different class from
the System.Data.DataSet. That might be irrelevant, but given your
question about the GridView I just wanted to make sure.
-----Original Message-----
[mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Ackerman, Cameron
T HEC
Sent: Tuesday, September 30, 2008 7:09 PM
To: gdal-dev at lists.osgeo.org
Subject: [gdal-dev] Data Binding dgal Layer in .NET
Hi All:
I'm a noob and trying to bind information from a Layer in GDAL
to a Datagridview in .NET.  Does anyone have experience or
a sample to get me started?  I'm trying to get around NOT
creating a copy of the data into a specialized class object
but use it in it's native form.
Many thanks,
cam
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
