[gdal-dev] gdal2tiles.py - can additional Zoom levels be forced?
Jamie Adams jaadfoo at gmail.com
Fri Oct 3 00:56:22 EDT 2008
Hey Roger,
You can always make create an up-sampled VRT of the source image with
"gdalwarp -of VRT -tr x y".  Yes, it does involve an additional step, but
the VRT takes almost no time to create and doesn't waste disk space.  You
can then use that as the input to gdal2tiles.  From the limited tests I've
tried it seems to work well.
"These go to eleven......"
-Jamie
On Thu, Oct 2, 2008 at 9:12 AM, Roger André <randre at gmail.com> wrote:
> I'm testing gdal2tiles.py this morning and am very encouraged by the
> results I''m seeing.  However, I would like to force the generation of Zoom
> levels greater than what the tool decides is reasonable.  Is this possible
> without diving into the code?  I'm currently getting tiles generated through
> Zoom level 7, and I would like to go to 11.
> 11 *is* after all a magic number. ;)
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20081002/74f19d9d/attachment-0001.html
