[gdal-dev] is there a way to rename fields with gdal/ogr 1.5.x?
Duarte Carreira DCarreira at edia.pt
Fri Oct 3 13:20:46 EDT 2008
Hi all.
I was trying to convert & rename a shapefile and getting syntax errors with the -sql string... So I'm wondering if this is working in 1.5.x or only in 1.6dev?
If it's not working in 1.5 is there any other way to accomplish this in this version?
Thanks,
Duarte Carreira
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20081003/2e10cedb/attachment.html
