[gdal-dev] is there a way to rename fields with gdal/ogr 1.5.x?
Tamas Szekeres szekerest at gmail.com
Mon Oct 6 17:45:16 EDT 2008
Here is my daily snapshot you can probably test with:
http://vbkto.dyndns.org:1280/tests/release-1400.zip
Best regards,
Tamas
2008/10/6 Duarte Carreira <DCarreira at edia.pt>:
> Tamas,
> Thanks for your reply.
> The problem to using the latest FWTools is the missing SDE plugin...
> compiling it myself is behond my knowledge. That's why I was hoping for a
> workaround with 1.5.x. Do you suppose I could get a compiled copy??
> Regards,
> Duarte
> De: Duarte Carreira [mailto:DCarreira at edia.pt]
> Enviada: sexta-feira, 3 de Outubro de 2008 18:21
> Para: gdal-dev at lists.osgeo.org
> Assunto: [gdal-dev] is there a way to rename fields with gdal/ogr 1.5.x?
> Hi all.
> I was trying to convert & rename a shapefile and getting syntax errors with
> the -sql string… So I'm wondering if this is working in 1.5.x or only in
> 1.6dev?
> If it's not working in 1.5 is there any other way to accomplish this in this
> version?
> Thanks,
> Duarte Carreira
> gdal-dev mailing list
