[gdal-dev] Shift/Translate vector data within the same coordinate system
John C. Tull john.tull at wildnevada.org
Tue Oct 7 13:10:13 EDT 2008
On Oct 7, 2008, at 8:45 AM, Frank Warmerdam wrote:
> It should be possible to specify a -s_srs and -t_srs that match the
> actual coordinate system, except using a different false easting/
> northing
> for the source srs.  This would result in an offset in x and y
> similar to
> the difference in false easting/northing.
That's a great trick to know about. I doubt I would have thought of
that solution.
Thanks,
John
