[gdal-dev] GDAL Releases [Scanned]
Dale Harris dharris at regisresources.com
Wed Oct 8 01:45:40 EDT 2008
Ok thanks for that. Any idea on the timeline for the beta release?
-----Original Message-----
From: Frank Warmerdam [mailto:warmerdam at pobox.com]
Sent: Wednesday, 8 October 2008 1:27 PM
To: Dale Harris
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] GDAL Releases [Scanned]
Dale Harris wrote:
> I would like to see ticket 2585 be resolved. This has been available
> MITAB since February and Mapinfo has support date fields for a few
> now.
I get the impression this fix will not make it into the 1.5.x stable
releases, but that it should make it into 1.6.0 (with luck the first
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
This message may contain privileged and confidential information.  If you are not the intended recipient of this message, you are notified that any use, dissemination, distribution or reproduction of this message is strictly prohibited.  If you receive this message in error, please notify Regis Resources Limited immediately.
