[gdal-dev] Gdal.Polygonize and SWIGTYPE_p_OGRLayerShadow
Asger Sigurd Petersen ASP at blominfo.dk
Wed Oct 8 04:00:43 EDT 2008
Hi Tamas,
Thank you very much! It works beautifully now.
Thanks again.
Best regards
Asger
-----Original Message-----
From: Tamas Szekeres [mailto:szekerest at gmail.com]
Sent: 8. oktober 2008 00:14
To: Asger Sigurd Petersen
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] Gdal.Polygonize and SWIGTYPE_p_OGRLayerShadow
Asger,
I've committed a change in the SVN-trunk so as to support this function. Check out and let me know how it goes.
Best regards,
Tamas
2008/10/7 Asger Sigurd Petersen <ASP at blominfo.dk>:
> Hi,
> I would like to use Gdal.Polygonize from C# using the SWIG bindings,
> but Polygonize doesn't accept an OSGeo.OGR.Layer object for the vector
> output, rather it demands a SWIGTYPE_p_OGRLayerShadow object. Problem
> is that it looks as if there is no way to instantiate a
> SWIGTYPE_p_OGRLayerShadow object, making it impossible to use Polygonize from C#.
> Can anyone confirm my observations?
> Best regards
> Asger
> asp at blominfo.dk
> +45 3525 5511
> BlomInfo A/S
> Masnedøgade 20
> DK-2100 KØBENHAVN Ø
> Phone: +45 7020 0226
> Fax: +45 7020 0227
> www.blominfo.dk
> gdal-dev mailing list
