[Gdal-dev] Trouble reading Geotiff projection
CELLIER François FRCE at teamlog.com
Wed Oct 8 12:48:51 EDT 2008
Hi everybody,
I need to read geotiff with the gdal library. This geotif had no projection
so I opened it through Global Mapper and Export it in order to have a
projection within it. When I do a gdalinfo on the file I have :
Driver: GTiff/GeoTIFF
Files: testAvecProj.tif
Size is 4000, 4000
Coordinate System is:
PROJCS["NTF (Paris) / France II",
    GEOGCS["NTF (Paris)",
        DATUM["Nouvelle_Triangulation_Francaise_Paris",
            SPHEROID["Clarke 1880 (IGN)",6378249.2,293.4660212936265,
                AUTHORITY["EPSG","7011"]],
            AUTHORITY["EPSG","6807"]],
        PRIMEM["Paris",2.33722917],
        UNIT["degree",0.0174532925199433],
        AUTHORITY["EPSG","4807"]],
    PROJECTION["Lambert_Conformal_Conic_1SP"],
    PARAMETER["latitude_of_origin",46.8],
    PARAMETER["central_meridian",0],
    PARAMETER["scale_factor",0.99987742],
    PARAMETER["false_easting",600000],
    PARAMETER["false_northing",2200000],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]],
    AUTHORITY["EPSG","27582"]]
Origin = (601499.999999999420000,2428999.999999997700000)
Pixel Size = (0.125000000000000,-0.125000000000000)
Metadata:
  AREA_OR_POINT=Area
Image Structure Metadata:
  COMPRESSION=PACKBITS
  INTERLEAVE=BAND
Corner Coordinates:
Upper Left  (  601500.000, 2429000.000) (  0d 1'13.55"E, 48d51'33.85"N)
Lower Left  (  601500.000, 2428500.000) (  0d 1'13.54"E, 48d51'17.67"N)
Upper Right (  602000.000, 2429000.000) (  0d 1'38.07"E, 48d51'33.84"N)
Lower Right (  602000.000, 2428500.000) (  0d 1'38.06"E, 48d51'17.66"N)
Center      (  601750.000, 2428750.000) (  0d 1'25.80"E, 48d51'25.75"N)
Band 1 Block=4000x1 Type=Byte, ColorInterp=Palette
  Color Table (RGB with 256 entries)
    0: 31,45,31,255
    1: 30,52,40,255
    2: 41,50,29,255
    3: 39,46,35,255
    4: 44,57,42,255
To read it I started from the example of the gdal website :
http://www.gdal.org/gdal_tutorial.html
GDALAllRegister();
this->_pGDALDataSet = (GDALDataset *) GDALOpen( _NomFichierImport.c_str(),
GA_ReadOnly );
In debug mode, the pszProjection field of _pGDALDataSet is :
PROJCS[“unamed”,GEOGCS[“unamed”,DATUM[“unknown”,SPHEROID[“unretrievable’
etc
Can someone tell me what I did wrong ?
Best regards,
François
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20081008/c9c64c2a/attachment.html
