[gdal-dev] ogr option-spat
Guillaume Sueur guillaume.sueur at neogeo-online.net
Thu Oct 9 08:19:27 EDT 2008
Weird to say why it doesn't work when you don't know yourself what it
should really do...
This option (and not function) is designed to extract a specific extent
of your input data when using ogr2ogr.
Actually it SHOULD work as I use it really often. Check your
data/values/result, and provide more precise test case if it doesn't.
regards
Guillaume
GOUBET LIONEL a écrit :
> Hi,
> How use the options –spat XMIN YMIN XMAX YMAX ?
> I try but it doesn’t work … All data layer is returned (same if I add in
> a table these columns).
> What’s the problem ? What’s the utility of this focntion ?
> Thanks you
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Guillaume SUEUR
Gérant
Neogeo Technologies SARL
46 RUE MATABIAU
31000 TOULOUSE
Tél : +33 6 74 91 95 20
http://www.neogeo-online.net
