[gdal-dev] GDAL Releases
Even Rouault even.rouault at mines-paris.org
Thu Oct 9 13:41:18 EDT 2008
Credits belong to FrankW for the hdf5 fix ;-)
Which version of the hdf4 library are you using ? What errors do you get ? etc
etc.
Please make a ticket with all that if you want to have a chance that things
get fixed. http://trac.osgeo.org/gdal/newticket
Le Thursday 09 October 2008 19:27:59 Andrew Brooks, vous avez écrit :
> On Wed, 08 Oct 2008 22:31:08 +0100, Even Rouault
<even.rouault at mines-paris.org> wrote:
> > FYI, with the fix done in http://trac.osgeo.org/gdal/ticket/2297, I've
> > successfully built GDAL trunk with a HDF5 1.8.1 library (built from the
> > source without any particular config option).
> You're right about hdf5, sorry, I was convinced I had to modify it but
> your fix was sufficient.
> However I did have to modify the following files to get gdal to build:
> frmts/hdf4/hdf4imagedataset.cpp
> frmts/hdf4/hdf-eos/SWapi.c
> frmts/hdf4/hdf-eos/GDapi.c
> frmts/hdf4/hdf4dataset.cpp
> Andrew
