[gdal-dev] gdal_polygonize losing the projection info?
Tue Oct 14 12:57:48 EDT 2008
Tyler Erickson wrote:
> I have been trying to use gdal_polygonize to convert a TIF to an ESRI
> Shapefile, but it seems to be losing the projection information (i.e. no
> *.prj file is created).
> The following output illustrates the loss of projection information.
> I'm currently using gdal trunk revision 15512.
> Any suggestions on how to keep the projection info?
This was a problem with the gdal_polygonize.py script.  I have modified it
to preserve the coordinate system when creating an output file in subversion.
Best regards,
