[gdal-dev] get fmrt grib
Limei Ran lran at unc.edu
Wed Oct 15 10:41:48 EDT 2008
Hi Frank:
I got gdal-svn-trunk-2008.10.14.tar.gz.  When I compiled it on Linux
server 32bits I got the following errors:
gt_overview.cpp: In function `toff_t GTIFFWriteDirectory(TIFF*, int,
int, int, int, int, int, int, int, int, int, int, int, short unsigned
int*, short unsigned int*, short unsigned int*, int, short unsigned
int*, const char*)':
gt_overview.cpp:75: error: `TIFFFreeDirectory' was not declared in this scope
gt_overview.cpp:75: warning: unused variable 'TIFFFreeDirectory'
make[2]: *** [../o/gt_overview.o] Error 1
make[2]: Leaving directory
`/nas/uncch/depts/cep/emc/lran/mims/mimssp_10_2007/src/libs/gdal-svn-trunk-2008.10.14/frmts/gtiff'
make[1]: *** [gtiff-install-obj] Error 2
make[1]: Leaving directory
`/nas/uncch/depts/cep/emc/lran/mims/mimssp_10_2007/src/libs/gdal-svn-trunk-2008.10.14/frmts'
make: *** [frmts-target] Error 2
Could you tell me how I can fix it?
Thanks,
Limei
Quoting Frank Warmerdam:
> Limei Ran wrote:
>> Hi:
>> Could you tell me how I can get grib format to build with gdal?  I
>> am using a server and I do not have svn or I can install one.  Can I
>> ftp grib format from somewhere?
> Limei,
> If you build from GDAL trunk (the development version) then GRIB format
> is included by default.  Try grabbing the "trunk" zip or .tar.gz from:
>  http://download.osgeo.org/gdal/daily/
> The 1.5 branch GRIB support is considerably harder to setup and I think is
> lacking in a number of other details.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
