[Gdal-dev] OGR: DXF driver
Andreas Neumann a.neumann at carto.net
Wed Oct 15 11:18:37 EDT 2008
Frank,
can you do a very rough estimate how much it would cost to implement the
read/write dxf driver based on your proposal? Would you deal with dwgs
also, or just dxf - how similar/different are dxf and dwg?
We could help financing it, but not the whole thing. If a couple of
interested parties would collaborate for the financing it could work.
dxf would definitely be interesting to have in ogr. I know that there can
be a wide variety of dxf files from the different products that generate
dxf.
Andreas
> Fodder wrote:
>> Hi Frank,
>> Thanks, this would be great, although I can't fund it in completion
>> (Euro
>>>>>> Aussie dollar :) .Would you be prepared to develop just the READ
>>>>>> side
>> of the driver, and what do you think that would cost (without styling)?
> Fodder,
> I would be willing to implement only read support, though it would not
> reduce the pricing all that much.
>> Alternatively, are other users/organisations interested in jointly
>> contributing?
>> On your proposal, you say that it would not support REGION, is it normal
>> for
>> polygons to be recorded as special polylines in DXF (such as from
>> AutoCAD
>> for example)?
> I'm afraid I'm not entirely sure what is normal.  I reviewed DXF docs,
> a couple example files, and the GRASS DXF import program in preparing the
> proposal, but DXF is still a bit of a mystery to me.  The proposal was
> deliberately simplistic to match my current level of understanding.
>> Would it support attributes, such as a DXF of contour lines with
>> elevation
>> attributes?
> Generally no, though there is some opportunity improve the driver a bit
> for easily recognizable attributes.  I have avoided doing a DXF driver for
> many years because while the format is not so complicated, there are a
> wide variety of ways for applications to encode complete geometries and
> attach attributes.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Andreas Neumann
Böschacherstrasse 6, CH-8624 Grüt/Gossau, Switzerland
Email: a.neumann at carto.net, Web:
* http://www.carto.net/ (Carto and SVG resources)
* http://www.carto.net/neumann/ (personal page)
* http://www.svgopen.org/ (SVG Open Conference)
* http://www.geofoto.ch/ (Georeferenced Photos of Switzerland)
