[Gdal-dev] OGR: DXF driver
Brent Fraser bfraser at geoanalytic.com
Wed Oct 15 11:56:50 EDT 2008
Frank Warmerdam wrote:
> I would note that the activity is not terribly complicated, and I would
> welcome others taking a crack at it.  I am not particularly trying to drum
> up business for myself here.
> I should also note that there is a contributed "write only" dxf driver
> sitting in Trac currently waiting for integration.  It is using dxflib
> (which I'm not so keen on), and doesn't do the read side that is of
> greatest interest.  But it might be a base on which someone could build
> the read side of things.
>   http://trac.osgeo.org/gdal/ticket/2555
> Best regards,
Frank,
  FYI, there's a minimalist DXF reader in VTP (VTP\TerrainSDK\vtdata\DxfParser.cpp).  Likely a little too c++ for GDAL/OGR to be used as-is, but might be a useful supplement to the doc you've gathered (and the licensing is as libre as it gets).
Brent Fraser
