[gdal-dev] error using gdaltindex on grass rasters
Jamie Adams jaadfoo at gmail.com
Wed Oct 15 16:47:47 EDT 2008
I'm using GDAL 1.5.2 built on Ubuntu 8.04.
On Wed, Oct 15, 2008 at 1:45 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Wed, Oct 15, 2008 at 7:29 PM, Jamie Adams <jaadfoo at gmail.com> wrote:
> > Hello all,
> > I needed to create a shapefile index of all the rasters in a grass mapset
> so
> > I ran:
> > ls /grass/location/mapset/cellhd/* | xargs gdaltindex all.shp
> > and got this error:
> > Warning 1: GRASS warning: Unable to open datum table file
> > </usr/local/share/gdal/grass//etc/datum.table>
> > /usr/local/share/gdal/grass//etc/ellipse.table: No such file or directory
> > Warning 1: GRASS warning: Unable to open ellipsoid table file
> > </usr/local/share/gdal/grass//etc/ellipse.table>
> > Warning 1: GRASS fatal error: Invalid ellipsoid <wgs84> in file
> Since GDAL 1.3.1 it should be resolved, see
> http://trac.osgeo.org/gdal/ticket/822
> Which version do you use?
> Markus
> > I created a symlink 'grass' in /usr/local/share/gdal/ pointing to my
> grass
> > install root, and that seemed to fix the issue.
> > I built both gdal and grass from source, plus added gdal-grass read
> support
> > via http://trac.osgeo.org/gdal/wiki/GRASS.  Should gdaltindex work
> as-is, or
> > did I miss a step somewhere?
> > Thanks,
> > -Jamie
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Open Source Geospatial Foundation
> http://www.osgeo.org/
> http://www.grassbook.org/
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20081015/0cbfbfb5/attachment.html
