[gdal-dev] Reprojection of textual lat-longs from Python script
Thu Oct 16 11:11:51 EDT 2008
James_Cook at blm.gov wrote:
> I understand that GDAL/OGR includes the Proj.4 library, but I haven't found
> any documentation explaining how I can transform a textfile of NAD27
> coordinates to NAD83 from a Python script.  Can anyone point me in the
> right direction?
Jim,
There is some information on GDAL/OGR coordinate system services (in terms
of the C++ API) at:
   http://www.gdal.org/ogr/osr_tutorial.html
You might also find the following python script useful as an example
of coordinate system services:
   http://svn.osgeo.org/gdal/trunk/gdal/swig/python/samples/tolatlong.py
Also, from the commandline you could use the following to transform
a text file of NAD27 points to NAD83:
  gdaltransform -s_srs NAD27 -t_srs NAD83 < nad27.txt > nad83.txt
Best regards,
