[gdal-dev] visual leak detector support
Norman Barker nbarker at ittvis.com
Thu Oct 16 13:32:40 EDT 2008
I see that visual leak detector support has been added to gdal
nmake.opt, and I have turned this on.
However the visual studio project files use a make file configuration,
how do you actually get the leak detector to work?
The docs at http://trac.osgeo.org/gdal/ticket/2009 are a little sparse.
thanks,
Norman
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20081016/5d21ff9f/attachment.html
