[gdal-dev] Odd things after using ogr2ogr
Kai Behncke Kai-Behncke at gmx.de
Wed Oct 22 15:32:02 EDT 2008
Dear users,
I have tried to find out for several hours a misterious thing.
I have downloaded data from Open Street Map. With Quantum GIS I selected some streets
 and exported that selection to a new shapefile (selektion_roads).
Eveything seems to be fine.
With ogrinfo I get the following output:
http://www.selbstverwaltung-bundesweit.de/test/selektion_roads_4326.PNG
Than I reprojected these data with ogr2ogr.
I did like that:"ogr2ogr -t_srs epsg:31467 E:/selektion_roads_31467.shp E:/selektion_roads.shp
Again I did "ogrinfo" and everything looks fine:
http://www.selbstverwaltung-bundesweit.de/test/selektion_roads_31467.PNG
then the weird thing start. I Load "selektion_roads_4326" in Quantum GIS (under the 4326-projection)
and after that "selektion_roads_31467" (here I use on the fly the 4326-projection)
but the layer don`t lay over each other, there is a mismatch of about 50 meter.
See her:
http://www.selbstverwaltung-bundesweit.de/test/mystery.PNG
How can this be?  Might this be a bug in reprojection?
Thank you for any hints in advance, Kai
Psssst! Schon vom neuen GMX MultiMessenger gehört? Der kann`s mit allen: http://www.gmx.net/de/go/multimessenger
