[gdal-dev] Projection info when creating GeoTIFFs
Andrea Battisti battisti at actgate.com
Fri Oct 24 06:45:51 EDT 2008
Hi all,
I have a quick question on how the Projection information is handled
when creating GeoTIFF files using GDAL's GTIFF driver.
As stated here:
http://www.gdal.org/frmt_gtiff.html
GDAL uses some auxiliary .csv files to pick-up the correct CS.
>From this message:
http://lists.osgeo.org/pipermail/gdal-dev/2008-October/018555.html
I see that those files are: pcs.csv and gcs.csv but it is unclear to me
if they should (or not) be edited adding the desired projection.
How does the process work for a generic Projection?
As an example, what are the steps needed to convert an existing file
using the 'tpeqd' projection (wkt: 'PROJECTION["Two_Point_Equidistant"]' )
to a GeoTIFF file with the same projection?
Using GDAL's CreateCopy doesn't seem to preserve that projection, while
it does with different output drivers, e.g. HFA, VRT...
Thanks in advance!
Andrea Battisti
Applied Coherent Technology Corp.
