[gdal-dev] JPEG2000 question/issue
Even Rouault even.rouault at mines-paris.org
Mon Oct 27 15:11:26 EDT 2008
Look at the 'Code' column athttp://gdal.org/formats_list.html
or the code reported by "gdalinfo --formats"
Le Monday 27 October 2008 16:38:48 Nidel, Mike, vous avez écrit :
> Interesting. I'd like to disable NITF handling, is this also possible
> in the same way using GDAL_SKIP? Where is the definitive list of format
> names that can be used in this way?
> thanks,
> Mike
> > -----Original Message-----
> > From: gdal-dev-bounces at lists.osgeo.org
> > [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Frank Warmerdam
> > Sent: Monday, October 27, 2008 11:24 AM
> > To: Christiaan Janssen
> > Cc: gdal-dev at lists.osgeo.org
> > Subject: Re: [gdal-dev] JPEG2000 question/issue
> > Christiaan Janssen wrote:
> > > I'm wondering if someone can help me with this. I'm trying to build
> > > GDAL with both support for MrSID and ECW while using the former for
> > > JPEG2000 support. It appears that as soon as libecw is
> > linked in, it
> > > is being used as the JPEG2000 reader (even when I have
> > MRSID_FLAGS =
> > > -DMRSID_J2K uncommented in the make options). I'm assuming this
> > > probably has something to do with the order that the
> > drivers are tried
> > > at runtime. Is there a correct way to force the support to
> > default to
> > > the MrSID library? Thanks for the help.
> > Christiaan,
> > Disabling the -DMRSID_J2K should disable the JP2MRSID driver
> > though you may need to do a clean build for the change in the
> > nmake.opt to take effect.
> > Alternatively you can force a particular driver to be ignored
> > at runtime using the GDAL_SKIP configuration variable.  Set
> > it to the driver name you want to ignore ... such as JP2MRSID.
> > It can be set in the environment, before running GDAL commands.
> > set GDAL_SKIP=JP2MRSID
> > Best regards,
> > I set the clouds in motion - turn up   | Frank Warmerdam,
> > warmerdam at pobox.com
> > light and sound - activate the windows | http://pobox.com/~warmerdam
> > and watch the world go round - Rush    | Geospatial
> > Programmer for Rent
> > gdal-dev mailing list
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
