[gdal-dev] MSYS buildslave
Wed Oct 29 10:41:31 EDT 2008
Ari Jolma wrote:
> All,
> I've set up a buildslave, which builds GDAL from a fresh checkout of the
> trunk in Windows using the MSYS environment. Currently the build is
> quite lean and only Perl bindings are built in addition to the core dll
> and apps. Only Perl tests are run.
Ari,
Excellent!  The one addition I'd be particularly keen to see would be
building the python bindings and running the python test suite since it
is our comprehensive "standard" test suite.
Best regards,
