[Gdal-dev] SQLite problem
Wed Oct 29 15:24:48 EDT 2008
iomeneandrei wrote:
> Hi all,
> I have created a sqlite spatial db with ogr2ogr, starting from a simple
> shapefile.
> I'm able to read the proper info of this sqlite db with ogrinfo.
> If I add a column to this sqlite db inside the table where I have the
> WKT_GEOMETRY, ogrinfo is no more able to read properly this db.
> Is it possible to add a column to  a sqlite spatial db without destroy the
> spatial component?
> I'm using SQLite Manager 0.3.15 for firefox to edit the db.
> I'm attaching the original sqlite file:
> http://www.nabble.com/file/p20233548/output1.sqlite output1.sqlite
Andrea,
The file you referenced seems to work fine with my (trunk) ogrinfo.  Can you
provide an example that ogrinfo can't read?  Generally, adding new columns to
a spatial table should not cause problems for OGR.
Best regards,
