[Gdal-dev] SQLite problem
iomeneandrei aborruso at tin.it
Wed Oct 29 18:39:19 EDT 2008
Hi Frank,
thank you very much.
Frank Warmerdam-2 wrote:
> The file you referenced seems to work fine with my (trunk) ogrinfo.  Can
> you
> provide an example that ogrinfo can't read?  Generally, adding new columns
> to
> a spatial table should not cause problems for OGR.
The file I have attache was the right one.
I have used this query:
ALTER TABLE "main"."output" ADD COLUMN "test" VARCHAR
And I have had the file I'm attaching now
http://www.nabble.com/file/p20237327/output2.sqlite output2.sqlite .
I'm not able to read it with ogrinfo.
My sqlite client is this:
https://addons.mozilla.org/en-US/firefox/addon/5817
Thank you,
Andrea
Andrea Borruso
email: aborruso at tin.it
blog: http://blog.spaziogis.it
View this message in context: http://www.nabble.com/SQLite-problem-tp20233548p20237327.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
