[gdal-dev] GDAL/OGR 1.6.0 Beta 1 Available
Kolberg Sjur A Sjur.A.Kolberg at sintef.no
Thu Oct 30 10:17:49 EDT 2008
Hello,
I just built GDAL1.6beta1 under Windows, VS2005, using the compiler IDE and modified project files distributed from http://vterrain.org/Distrib/gdal.html. Builds and tests fine with some GRIB, HDF4 and HDF5 data, if someone wants the updated VS2005 project file let me know.
Sjur  :-)
Sjur Kolberg
SINTEF Energiforskning A/S
Sem Sælands vei 11
7465 Trondheim
tlf. 73 59 72 78
fax  73 59 72 50
> -----Original Message-----
> From: gdal-dev-bounces at lists.osgeo.org
> [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Frank Warmerdam
> Sent: 30 oktober 2008 04:00
> To: gdal-dev; gdal-announce at lists.osgeo.org
> Subject: [gdal-dev] GDAL/OGR 1.6.0 Beta 1 Available
> Folks,
> I have prepared the GDAL/OGR 1.6.0 Beta1 release.  This is
> the first of two planned betas, the second is planned for
> November 12th.  The source is available at:
>    http://download.osgeo.org/gdal/gdal-1.6.0beta1.tar.gz
>    http://download.osgeo.org/gdal/gdal160beta1.zip
> I have also snapped the Python autotest suite.  It can be
> downloaded from:
>    http://download.osgeo.org/gdal/gdalautotest-1.6.0-beta1.tar.gz
>    http://download.osgeo.org/gdal/gdalautotest-1.6.0-beta1.zip
> Instructions on running and interpreting the autotest suite
> are available
> at:
>    http://trac.osgeo.org/gdal/wiki/TestingNotes
> Andrey Kiselev will be preparing test matrix document very
> soon in which notes can be made about test coverage:
>    http://trac.osgeo.org/gdal/wiki/TestMatrix160
> New bugs found should be filed in Trac normally.
> GDAL developers and users are encouraged to treat the coming
> two weeks as the "prime time" for bug finding and fixing.
> Once beta2 starts we will take a more cautious approach to changes.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial
> Programmer for Rent
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
