[gdal-dev] GDAL/OGR 1.6.0 Beta 1 Available
Thu Oct 30 10:46:27 EDT 2008
Frank Warmerdam wrote:
> Folks,
> I have prepared the GDAL/OGR 1.6.0 Beta1 release.  This is the first of
> two planned betas, the second is planned for November 12th.  The source is
> available at:
>   http://download.osgeo.org/gdal/gdal-1.6.0beta1.tar.gz
>   http://download.osgeo.org/gdal/gdal160beta1.zip
> I have also snapped the Python autotest suite.  It can be downloaded from:
>   http://download.osgeo.org/gdal/gdalautotest-1.6.0-beta1.tar.gz
>   http://download.osgeo.org/gdal/gdalautotest-1.6.0-beta1.zip
Folks,
I neglected to mention that the 1.6.0 beta1 source has been used in the
latest FWTools for windows (2.2.8):
   http://home.gdal.org/fwtools/FWTools228.exe
Also, the "gdal-dev" package in OSGeo4W has been updated with the beta
source.
   http://osgeo4w.osgeo.org/
The gdal-dev package needs to be installed via the "advanced install"
sequence.  Once installed you need to run the "gdaldev" bat file in the
OSGeo4W command shell to use the gdal-dev package instead of the 1.5.3
version for the gdal utilities and python scripts.
Note that there is currently no way in OSGeo4W to use gdal-dev with other
GDAL using packages like MapServer, or OpenEV which always use the
standard GDAL package (1.5.3).
Best regards,
