[gdal-dev] MSYS buildslave
Andrey Kiselev dron at ak4719.spb.edu
Thu Oct 30 10:38:42 EDT 2008
On Wed, Oct 29, 2008 at 02:04:44PM +0200, Ari Jolma wrote:
> I've set up a buildslave, which builds GDAL from a fresh checkout of
> the trunk in Windows using the MSYS environment. Currently the build
> is quite lean and only Perl bindings are built in addition to the core
> dll and apps. Only Perl tests are run.
Ari,
If you are planning to extend a build to include NG Python bindings note
that there is one problem. For some reason module built from
swig/python/extensions/gdalconst_wrap.c cannot be loaded by the stock
Python binaries (built with MSVS 2003). I have ended up renaming that
file in gdalconst_wrap.cpp with the appropriate change in
swig/python/setup.py and everything works fine after that. The problem
is weird and I failed to pin it down, so the above workaround.
Otherwise of that bug Python stuff should be perfectly compilable and
usable with the official binary Python distribution.
Best regards,
Andrey
Andrey V. Kiselev
ICQ# 26871517
