[gdal-dev] gdal_priv.h not found on ubuntu
Thu Oct 30 11:13:47 EDT 2008
Matt Wilkie wrote:
>> Try:
>> g++ -I/usr/include/gdal hillshade.cpp -lgdal -o hillshade
> Thank you for the suggestion, still no good though:
> :~/src/demtools$ g++ -I/usr/include/gdal hillshade.cpp -lgdal -o hillshade
> /usr/bin/ld: cannot find -lgdal
> collect2: ld returned 1 exit status
Matt,
I don't know where the gdal library gets put, perhaps /usr/lib/gdal?
If so, it might help to do:
  g++ -I/usr/include/gdal hillshade.cpp -L/usr/lib/gdal -lgdal -o hillshade
You might also find the following works for you:
  g++ `gdal-config --cflags` hillshade.cpp -o hillshade `gdal-config --libs`
Best regards,
