[gdal-dev] Custom GDAL Driver with ArcGIS 9.3
Leonard, Kyle B kyle.leonard at honeywell.com
Thu Oct 30 13:36:14 EDT 2008
Has anyone had any luck with configuring a custom GDAL driver with
ArcGIS 9.3?
I have a custom raster DLL in the ESRI RDO format that I am trying to
convert to GDAL format.  I have followed the "GDAL Driver Implementation
Tutorial" found at http://www.gdal.org/gdal_drivertut.html.   I then
linked in ESRI's GDAL library found at
http://edn.esri.com/index.cfm?fa=downloads.detail&downloadId=204 to
create my new GDAL driver.  I then followed the configuration steps
provided on the ESRI Developer Network page previously noted, but ArcGIS
does not seem to recognize my DLL.
Any tips or tricks that you know of would be appreciated.
Thanks,
Kyle Leonard                                Honeywell Aerospace
Database Engineer                                       15001 NE 36th St
(M/S L2A)
EGPWS Engineering                                     Redmond, WA
98073-9701
TEL:  (425) 885-8118
kyle.leonard at honeywell.com                   FAX: (425) 885-2994
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20081030/eb1d3d46/attachment.html
