Re: [gdal-dev] Custom GDAL Driver with ArcGIS 9.3
Lucena, Ivan ivan.lucena at pmldnet.com
Thu Oct 30 14:14:19 EDT 2008
Kile,
I did the same thing years a go. I wrote a RDO then I it converted it to a GDAL 1.3 driver and latter I set it up as a GDAL plugin to be
seem by ArcGIS 9.2. One thing that helped me a lot was to load everything in a VC2003 project and run ArcMAP in debug mode. But
you probably know that.
Thanks to tell us that they decided to make their GDAL branch public. Some people were waiting for that. I apologize for given the
wrong information a week ago.
Ivan
>  -------Original Message-------
>  From: Leonard, Kyle B <kyle.leonard at honeywell.com>
>  Subject: [gdal-dev] Custom GDAL Driver with ArcGIS 9.3
>  Sent: Oct 30 '08 17:36
>  Has anyone had any luck with configuring a custom GDAL driver with ArcGIS
>  9.3?
>  I have a custom raster DLL in the ESRI RDO format that I am trying to
>  convert to GDAL format.  I have followed the “GDAL Driver
>  Implementation Tutorial” found at [LINK:
>  http://www.gdal.org/gdal_drivertut.html]
>  http://www.gdal.org/gdal_drivertut.html.   I then linked in ESRI’s
>  GDAL library found at [LINK:
>  http://edn.esri.com/index.cfm?fa=downloads.detail&downloadId=204]
>  http://edn.esri.com/index.cfm?fa=downloads.detail&downloadId=204 to create
>  my new GDAL driver.  I then followed the configuration steps provided on
>  the ESRI Developer Network page previously noted, but ArcGIS does not seem
>  to recognize my DLL.
>  Any tips or tricks that you know of would be appreciated.
>  Thanks,
>  KYLE LEONARD                                HONEYWELL AEROSPACE
>  Database Engineer                                       15001 NE 36th St
>  (M/S L2A)
>  EGPWS Engineering                                     Redmond, WA
>  98073-9701
>  TEL:  (425) 885-8118
>  [LINK: mailto:kyle.leonard at honeywell.com] kyle.leonard at honeywell.com
>  FAX: (425) 885-2994
>  _______________________________________________
>  gdal-dev mailing list
>  [LINK: compose.php?to=gdal-dev at lists.osgeo.org] gdal-dev at lists.osgeo.org
>  [LINK: http://lists.osgeo.org/mailman/listinfo/gdal-dev]
