[gdal-dev] GetExtent method
Tue Sep 2 11:55:25 EDT 2008
Clay, Bruce wrote:
> When I used the debugger to step into the OGRLayer GetExtent method I
> noticed that it walks through all of the features in the dataset and
> tests the envelope of each feature in the set.
> Are there any driver specific optimizations (i.e. OCI)  that could be
> called instead of this one since it does take a long time for a large
> dataset?
> I realize we can create our own but I would like to use a built in
> function if it is available.
> Frank: Since you are working in the OCI driver would this be a good time
> to add something like:
>             select min(a1.SHAPE.SDO_POINT.X),
>  max(a1.SHAPE.SDO_POINT.X),
>  min(a1.SHAPE.SDO_POINT.Y),
>  max(a1.SHAPE.SDO_POINT.Y) from DatasetName a1;
> Of course that falls back on the first question, is there already a
> built in method.
Bruce,
We already have a specialized implementation of OGROCITableLayer::GetExtent()
at:
http://trac.osgeo.org/gdal/browser/trunk/gdal/ogr/ogrsf_frmts/oci/ogrocitablelayer.cpp#L1072
I wonder if this optimized case is failing for some reason for you?  Or
perhaps you are working with an result from ExecuteSQL()?
Best regards,
