[gdal-dev] Countour polygons instead of lines
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Wed Sep 3 03:48:44 EDT 2008
On Wed, 2008-09-03 at 10:40 +0300, Ari Jolma wrote:
> > Indirectly, yes. You can use r.reclass to create areas of similar
> > elevation from the raster DEM and r.to.vect to covert to polygons.
Also, use the "-s" switch (in r.to.vect) to get smoothed and not edgy
polygons :-)
