[gdal-dev] OCI driver not adding data to Oracle Table
Lucena, Ivan ivan.lucena at pmldnet.com
Wed Sep 3 10:54:00 EDT 2008
Bruce,
I have seem this error message before and I think is it exactly what you
though but just for troubleshooting, could you try to re-create the
columns as NUMERIC without (precision,scale) and run it again. That will
point out where the error occurs. Maybe.
Ivan
Clay, Bruce wrote:
> I have been trying to use the OCI driver to create a table and load data
> into it.  I have been using the same code loop in the past to create
> shapefiles without problems.  No errors are reported during the
> CreateFeature and SetField process based on return status but no data
> shows up in the table.
> I added several calls to CPLGetLastErrorMsg and still do not get any
> reported errors.  I set a trap in OGROCITableLayer and walked down that
> path into FinalizeNewLayer and FlushPendingFeatures and finally got an
> error message pn the OCIStmtExecute call indicating that a "value was
> larger than specified precision allows for this column".  Unfortuneatly
> it did not indicate which column was in error.
> Is there any way to pin down the exact column?
> If did notice in the SetField that atof(string) returned more digits to
> the right of the decimal point than the precision specified.  Is that
> the likely cause of the problem?  The source data only has 8 characters
> to the right of the decimal point but the atof call returns more than 8
> when it converts the string retrieved from the source table in Oracle.
> Any thoughts would be greatly appreciated.
> Bruce
> This message and any enclosures are intended only for the addressee.  Please
> notify the sender by email if you are not the intended recipient.  If you are
> not the intended recipient, you may not use, copy, disclose, or distribute this
> message or its contents or enclosures to any other person and any such actions
> may be unlawful.  Ball reserves the right to monitor and review all messages
> and enclosures sent to or from this email address.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
