[gdal-dev] gdal error 4
Wed Sep 3 13:26:56 EDT 2008
Christian Willmes wrote:
> Hello,
> I have a problem with the gdal Installation on our webserver. I'm new to
> gdal, to be specific I try to get some raster data into mapserver, but
> there occours the following error according gdal and I could not find
> anything what helped me out on google and other mailinglists.
> I get the following Error when I try to access data with gdal:
> cwillmes at lvr18$ gdalinfo SRTM_Elevation.tif
> ERROR 4: `SRTM_Elevation.tif' not recognised as a supported file format.
> GDALOpen failed - 4
Christian,
I would carefully review permissions to see if that might be the issue.
I have stepped through the code and confirmed this is the sort of error
you get if you don't have read permissions on a file.  You might want to
file a ticket on this, so we can improve the reporting of errors related
to permissions.
Best regards,
