[gdal-dev] example GML v2.
Rushforth, Peter prushfor at NRCan.gc.ca
Thu Sep 4 15:21:37 EDT 2008
 Hi Nick,
There are lots of gml 2 files available from here, of varying size:
http://www.statcan.ca/english/mapsgeo/index2.htm
Cheers,
Peter
> -----Original Message-----
> From: gdal-dev-bounces at lists.osgeo.org
> [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of
> nicholas.g.lawrence at mainroads.qld.gov.au
> Sent: September 3, 2008 20:25
> To: gdal-dev at lists.osgeo.org
> Subject: [gdal-dev] example GML v2.
> Hello list,
> I am looking for a GML v2.1 file for testing purposes
> It does not have to be very large at all, or of any
> particular area, just enough to test that the import works.
> Any suggestions on where I can find one?
> Regards,
> nick
> WARNING: This e-mail (including any attachments) may contain
> legally privileged, confidential or private information and
> may be protected by copyright. You may only use it if you are
> the person(s) it was intended to be sent to and if you use it
> in an authorised way.  No one is allowed to use, review,
> alter, transmit, disclose, distribute, print or copy this
> e-mail without appropriate authority.
> If this e-mail was not intended for you and was sent to you
> by mistake, please telephone or e-mail me immediately,
> destroy any hardcopies of this e-mail and delete it and any
> copies of it from your computer system. Any right which the
> sender may have under copyright law, and any legal privilege
> and confidentiality attached to this e-mail is not waived or
> destroyed by that mistake.
> It is your responsibility to ensure that this e-mail does not
> contain and is not affected by computer viruses, defects or
> interference by third parties or replication problems
> (including incompatibility with your computer system).
> Opinions contained in this e-mail do not necessarily reflect
> the opinions of the Queensland Department of Main Roads,
> Queensland Transport or Maritime Safety Queensland, or
> endorsed organisations utilising the same infrastructure.
> gdal-dev mailing list
