[Gdal-dev] Attaching Text Files in NITF driver
Radeus troy at radeuslabs.com
Thu Sep 4 18:16:45 EDT 2008
Hello,
I'm new to GDAL and have not been able to find any information on whether
the NITF driver allows you to attach a text file (text segment) to the NITF
file on Create or CreateCopy. I have tried with no luck to either attach or
read back a NITF file with Text Segments.
I have seen that the GDALPamDataset will create the aux.xml filler with the
extra data when creating the NITF file, but the information is not actually
writen to the NITF file itself.
I am currently using build 1.5.2 compiled on VC++ 7.1 for Windows.
Is this simply not supported in the NITF driver?
If it is not supported, how hard would it be to add this in to the driver?
Thanks in advance-
View this message in context: http://www.nabble.com/Attaching-Text-Files-in-NITF-driver-tp19321160p19321160.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
