[Gdal-dev] Attaching Text Files in NITF driver
Radeus troy at radeuslabs.com
Fri Sep 5 12:24:49 EDT 2008
Frank Warmerdam-2 wrote:
> Radeus wrote:
>> Hello,
>> I'm new to GDAL and have not been able to find any information on whether
>> the NITF driver allows you to attach a text file (text segment) to the
>> NITF
>> file on Create or CreateCopy. I have tried with no luck to either attach
>> or
>> read back a NITF file with Text Segments.
>> I have seen that the GDALPamDataset will create the aux.xml filler with
>> the
>> extra data when creating the NITF file, but the information is not
>> actually
>> writen to the NITF file itself.
>> I am currently using build 1.5.2 compiled on VC++ 7.1 for Windows.
>> Is this simply not supported in the NITF driver?
>> If it is not supported, how hard would it be to add this in to the
>> driver?
> Radeus,
> You are correct that the NITF driver does not currently support writing
> text segments.
> It would not be particularly hard to add.  That means it might take me
> 2-3 hours. Someone unfamiliar with the driver might require a day to get
> to a stable and safe result.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Frank,
Other than implementing the SetMetadata() and SetMetadataItem() in the
NITFDataset, what else should I look at changing. I know I should be writing
this information from the GDALMultiDomainMetadata in the destructor (or at
least that is what I think based on GTiff implementation) but I have not
figured out how. Any advice would be greatly appreciated!
Best Regards-
View this message in context: http://www.nabble.com/Attaching-Text-Files-in-NITF-driver-tp19321160p19334826.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
