[gdal-dev] negative buffer
Clay, Bruce bclay at ball.com
Tue Sep 9 11:13:56 EDT 2008
I am trying to use GDAL to cluster a group of points.  I am creating a
buffer around the points then testing buffered points for intersection.
I am putting those that intersect into a GeometryCollection then
creating a convexHull to smooth the polygon.
All of that works ok but the problem is that the resultant polygon is
larger than is desired because of the buffer used to create the
intersections.
I tried to use a negative value with the Geometry Buffer method to
shrink the polygon back down to the proper size but Buffer always
returns a NULL pointer.  I stepped down into the call and it looks like
GEOS is returning a valid geometry but OGR rejects the polygon do to the
number of points being too low.  The initial buffer size is 1.5 Km so
smallest cluster has a minimum spatial diameter of 3 km.  I saw point
counts in the debugger of over 2000 so I am not sure why OGR appears to
reject the geometry that GEOS passed back.  I don't have GEOS compiled
with debug turned on so I could not step into that
Is there another way to reduce the size of a polygon or a smarter war to
cluster points?
Bruce
This message and any enclosures are intended only for the addressee.  Please
notify the sender by email if you are not the intended recipient.  If you are
not the intended recipient, you may not use, copy, disclose, or distribute this
message or its contents or enclosures to any other person and any such actions
may be unlawful.  Ball reserves the right to monitor and review all messages
and enclosures sent to or from this email address.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080909/195d7655/attachment.html
