[gdal-dev] Accessing OGRStyleTable
Daniel Morissette dmorissette at mapgears.com
Fri Sep 12 15:19:19 EDT 2008
Mateusz Łoskot wrote:
> Now I've got what's the problem.
> Yes, looks like this part of API is missing or for some reasons not
> planned. Perhaps Daniel or Frank will explain.
Style tables were part of the initial design, but were never implemented
for any driver as far as I know. That's why the API may still be incomplete.
Unless I'm mistaken, so far OGR returns styles only at the feature
level, so if you plan to use the stock OGR in your app you can probably
ignore the style table stuff for now.
OTOH, if you have implemented drivers that support style tables then
you're invited to contribute tickets, patches, or perhaps a RFC
describing what you consider is missing to the API to make it really useful.
Daniel
Daniel Morissette
http://www.mapgears.com/
