[gdal-dev] gdal 1.5.2's RADARSAT-2 driver
Fri Sep 12 15:40:49 EDT 2008
Gong, Shawn (Contractor) wrote:
> hi list,
> rephrase my 2nd question, is there a way to skip the "SubDataset
> Selection" dialog, and to load uncalibrated digital numbers by default?
Shawn,
I think this may be more of an OpenEV question, than it is a GDAL
question.  You can directly select the uncalibrated numbers by
using the appropriate subdatset name with GDAL.  You can use gdalinfo
to see the subdataset names of a dataset.
> *From:* gdal-dev-bounces at lists.osgeo.org
> [mailto:gdal-dev-bounces at lists.osgeo.org] *On Behalf Of *Gong, Shawn
> (Contractor)
> *Sent:* Friday, September 12, 2008 2:28 PM
> *To:* gdal-dev at lists.osgeo.org
> *Subject:* [gdal-dev] gdal 1.5.2's RADARSAT-2 driver
> hi list,
> I have installed gdal 1.5.2 on Windows, trying to test the RADARSAT-2
> driver.
> When loading RSAT-2 "product.xml", a "SubDataset Selection" dialog box
> pops up and asks user to select 1) uncalibrated digital numbers, 2)
> Sigma nought calibrated, 3) beta nought calibrated, 4) gamma calibrated.
> After selection, I got the error:
> Warning 1: TIFFReadDirectory:Unknown field with tag 34595 (0x8723)
> encountered
> and the "SubDataset Selection" dialog box reappears.
Hmm, this is odd. Would it be possible to make a dataset demonstrating
this problem available?
Best regards,
