[gdal-dev] Accessing OGRStyleTable
Geo Aspects Development dev at geoaspects.com
Sat Sep 13 07:07:39 EDT 2008
FWIW, here are the code fragments I added (to my copy of GDAL 1.4.0),
though I have subsequently changed my strategy and don't use it any
longer. This makes it possible to use the styles in a GUI, where you
can list available styles and have the user select one.
The DataSource/Layer/Feature hierarchy would definitely be useful (to
me!) But, long-term, wouldn't a more standards-based system (including
GDAL and OGR) like SLD be a better idea?
regards
Tim
In ogrfeaturestyle.cpp:
OGRStyleMgr
/*      const char
**OGRStyleMgr::GetStyleCount()                           */
int OGRStyleMgr::GetStyleCount()
     if (m_poDataSetStyleTable)
         return  m_poDataSetStyleTable->Count();
     return NULL;
/*      const char
**OGRStyleMgr::GetStyleNames()                           */
char **OGRStyleMgr::GetStyleNames()
         return  m_poDataSetStyleTable->GetStyleNames();
     return NULL;
OGRStyleTable                                             */
/*     Object Used to manage and store a
styletable                         */
/*             int
OGRStyleTable::Count()                                   */
/*   return the number of styles in the table otherwise return
-1           */
int OGRStyleTable::Count()
     return (m_papszStyleTable == NULL) ? -1 :
CSLCount(m_papszStyleTable);
/*             int
OGRStyleTable::GetStyleNames()                           */
/*   return a index of the style in the table otherwise return
-1           */
char **OGRStyleTable::GetStyleNames()
     static char **pszNameList = NULL;
     const char *pszName = NULL;
     const char *pszStyleStringBegin = NULL;
     char *pszTmp;
     if (pszNameList)
         CSLDestroy(pszNameList);
     pszNameList = NULL;
     for (int i=0; i<Count(); i++)
         pszStyleStringBegin = strstr(m_papszStyleTable[i],":");
         if (pszStyleStringBegin)
             pszName = CPLStrdup(m_papszStyleTable[i]);
             pszTmp = strstr(pszName,":");
             if (pszTmp)
                 pszTmp[0] = '\0';
                 pszNameList = CSLAddString(pszNameList, pszName);
     return pszNameList;
In ogr_featurestyle.h:
class CPL_DLL OGRStyleMgr
     int GetStyleCount();
     char **GetStyleNames();
class CPL_DLL OGRStyleTable
     int   Count();
On Sep 13, 2008, at 12:14 AM, Mateusz Łoskot wrote:
> Daniel Morissette pisze:
>>> Now I've got what's the problem.
>>> Yes, looks like this part of API is missing or for some reasons
>>> not planned. Perhaps Daniel or Frank will explain.
>> Style tables were part of the initial design, but were never
>> implemented for any driver as far as I know. That's why the API may
>> still be incomplete.
> Daniel,
> Thanks for clarifying it. OGR styling stuff is still a new beast to
> me.
>> OTOH, if you have implemented drivers that support style tables
>> then you're invited to contribute tickets, patches, or perhaps a
>> RFC describing what you consider is missing to the API to make it
>> really useful.
> Yes, I think it's reasonable approach.
> Best regards,
> Mateusz Loskot, http://mateusz.loskot.net
> Charter Member of OSGeo, http://osgeo.org
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
