[gdal-dev] a question
Tamas Szekeres szekerest at gmail.com
Wed Sep 17 05:23:48 EDT 2008
You can refer to the corresponding sample application in the source tree:
http://trac.osgeo.org/gdal/browser/trunk/gdal/swig/csharp/apps/GDALOverviews.cs
Best regards,
Tamas
2008/9/17 guo cheng <nudtchengguo at gmail.com>:
> how to use dataset.buildoverviews in C#.net.
> It seems there are only two parameters that are not enough.
> I hope you can give me an example.
> Thank you very much!
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
