[gdal-dev] projection locating image incorrectly.
Robert Beckwith Robert.Beckwith at delorme.com
Thu Sep 18 10:48:20 EDT 2008
I downloaded idaho9798landsatencw.sid and its companion files from
http://www.idwr.idaho.gov/ftp/gisdata/Spatial/Datareq/
When using gdal this image is re-projected in the wrong location
(Africa)
Using ArcCatalog it ends up in the correct location.
Other MrSid files I have used work correctly using gdal, and I have
tried various methods.
Can anyone else confirm this? And any clues to why this is happening?
I looked back a number of versions in gdal and MrSID and it still ends
up incorrectly located.
...thanks
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080918/c99884d3/attachment.html
