[gdal-dev] Fastest way to add the GeoTransform to a raster file with Python
Thu Sep 18 16:06:57 EDT 2008
On 9/18/08, Lucena, Ivan <ivan.lucena at pmldnet.com> wrote:
> Frank,
> Wouldn't be fair to say that some formats also requires a call to FlushCache() afterwards?
Ivan,
FlushCache may help push the updated geotransform out to the
file immediately for some formats.  But if you are just going to
close the dataset then that should already do the equivelent of
a FlushCache().  So, FlushCache() is only of use to try and
push updates out to a file without closing the file.
Whether it is implemented or not varies from driver to driver.
Best regards,
