[gdal-dev] MEM size limit
Mon Sep 22 12:25:15 EDT 2008
Ozy Sjahputera wrote:
> Hello everyone,
> According to the documentation in gdal.org, the in-memory file format
> (MEM) has a 2GB size limit. I recently used MEM to process an image
> whose size is larger than 2GB without encountering any error message.
> The output seems to be fine as well. Has the MEM driver been upgraded to
> handle image > 2 GB. I am using GDAL v1.5.2.
Ozy,
Yes, it appears that as part of treating bug #1503 this limitation was
removed on 64bit platforms.  I have removed the 2GB limit mention in
the formats_list.html file.
Best regards,
