[gdal-dev] 8-bit GeoTIFF and transparency over multiple bands
Vincent Schut schut at sarvision.nl
Tue Sep 23 07:58:14 EDT 2008
D wrote:
> I would need to know, if a three band (RGB) 8-bit GeoTIFF can have
> transparency enabled?
No, there would be no way to know the transparency for a pixel if there
are only red/green/blue values available. For that you'll need a 4-band
(rgba) image.
> I know that it is possible to enable transparency on a singleband TIFF.
In that case you'd have one band containing color indices instead of rgb
color values. These color indices than map into a rgba colortable which
defines color and transparency for that color index.
> Can someone confirm this?
> Best regards,
> Dejan Gregor
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
